Rough Country 3 Inch Lift With Pics
I know this threads a bit old, but I got a question for some people about this kit... I know theres mixed reviews but its still an option. I'm wondering what the benefits of going with their upper control arm/ball joint combo is? I know you dont have to cut out the bump stop, but is there any other advantage because it doesnt look adjustable at all. TIA
NOPE! If you want I still have the kit I took off my truck with the RC UCA's. I never had the heart to sell it to anyone, but if you just want to give away money then give it to me. :seeya:
In all seriousness that kit should never be an option.....never.
  • Replies 79
ok, fine then! lol , I'm having trouble finding any other options in that size of a lift, or something close. Anyone have any links to good online sites to buy from? or any suggestions on brands to look up? And I'm not big on body lifts as it seems you seem to be suggesting :troll: lol
Skyjacker makes a 3" the right way for $1400, Zone and BDS have 4" kits $13-1800.
Levelling kit and a 1.5 or 3" body will net you a good amount to run 33x1150's
(The levelling kit and a 1.5 body lift would net the same as the RC 3" - that kit basically levelled it and lifted about an inch and a half) - however in the wrong way. This setup is cheaper too! and ur angels stay better.
ok, fine then! lol , I'm having trouble finding any other options in that size of a lift, or something close. Anyone have any links to good online sites to buy from? or any suggestions on brands to look up? And I'm not big on body lifts as it seems you seem to be suggesting :wtf: lol
3" body, 2" leveling kit. :crazy:
so ive read all your post and am really wondering about this lift, my sister has a 1500 extra cab 2wd and wants to buy the rc 3". i told her WITHOUT a-arm's because i figured that they cant screw up a spacer and blocks that much. and plus why would you need them. i have had a 2inch on my 1500 for 15,000 miles and i see no problems. Do you think the 3 inch without arms would be okay?
2008 GMC Sierra 1500 reg short 5.3L 2inch front 2inch back
2008 GMC Sierra 3500 Duramax Crew Dually. Banks Power over 1000 hp.
No. Kiss your balljoints, tie rods and steering rack goodbye.
CST makes a nice 4.5" lift for the 2WD GMT900 trucks. It utilizes 3.5" lift spindles (that's 3.5" of lift without changing ANY angles) and a 1" spacer. I believe it also comes with rear blocks as well. If I had a 2WD truck, i'd definitely go this route. Install is a breeze and you won't screw with any reliability issues
ooo alright.. see i figured ive had my skyjacker 2inch on for 15,000 plus miles now and i havnt had any problems. (knock on wood). i was just wondering. thanks.
2" is about the max you want to go on these trucks. Higher than that is like Russian Roulette..... you can do it, and you may be OK... but there's a good chance you'll have issues.
  • 4 weeks later...
So I litterally was going to get this kit for my next mod. Thanks to all you guys, not a chance. Looks like I'll be waiting a while to save of the money and do it right..
alright well thanks i was really wonderin reading this.
Anyone have an opinion on the 3" rough country lift? ha ha
Yes, It is a great lift. Im going to buy another one when my income tax comes in.
Everyone looking at this lift need to just do the CCM 2.5 leveling kit and Zone 1.5" BL. I just finished my zone last weekend, and it looks so good now and even taller that it was with that RC 3" shit. And CMack, all you should do is add the Zone 1.5 to your leveling kit if you are looking for something similar to this piece of shit lift. I assure you, you won't have any of the issues you would with the RC and it is way cheaper.
I'd like to see where the "mixed reviews" are on this kit.
There are very good advantages to going with their UCA's. The advantages I had with them were:
1) They rub the coil on the strut everytime the axle droops all the way down
2) The front end never aligns properly
3) The bushings wear out and squeak like hell
  • 1 month later...
I'm just curious if anyone here with a negative opinion of this kit had the newest version? I keep seeing a lot of reviews from people that had the older one that really hated it but I'm wondering if the upgrades helped? And dont worry, I did the level with the 1.25" BL.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,629 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
