7-way Trailer Harness To 4-way Conversion, And Can I Tap It For A Powe
I didnt know where to put this, so i put it in the 1500 section.
My truck came with the 7-way Blade (RV-Style) connector, that looks like this...
For the life of me, i will never use this setup, and i have always used the standard 4-wire connector on my trucks.
That and, last year, somebody backed into me and luckily, only cracked off the mount to this connector...but also cracked the whole unit, so hense why i just want to convert it to 4-wire and forget it.
My question is, i see on the 7-way blade that there's obviously more wires that do more, but how much is that 12v Battery Charge able to handle? I was thinking about tapping off that wire, and putting something in the bed, like a 12v Outlet. I have a winch for my boat thats 12v electric, and i know its slim, but would the winch be able to draw off that wire? Or should i run a whole seperate cable thats thick (like my dad has)?
I would replace the existing 7-pin connector and go buy one of the 7-pin to 4-pin conversion plugs. That works fine for small trailers that use that type of connector.
The 12v power lead uses a 40A fuse in the underhood fuse center (it's either Stud #1 or Stud A but it;s marked onthe label under the cover) so you should be able to run small 12v items in a trailer. You can also buy 7-pin connectors and simply cut the 4-pin connector off the trailer harness and attach the 7-pin connector. You can then add an extra wire lead for the 12v pin back to whre you need it.
For a winch, you really need either a separate battery or run 4-6 gauge wire back to the truck battery. The 12v lead in the trailer connector will not be up to running a winch under load. If you put a battery on your trailer to run a winch, you can use the 12v pin and some wire to keep the battery charged up.
They sell the adaptor, but what I did, was cut the 4 wire plug OFF my Trailer. and installed a 7 wire plug on the trailer, only connecting the 4 wires necessary. The 4 wire plug on the trailers don't last very long anyway. that pin breaks off. so my problem is solved.
I would replace the connector put a battery on my boat trailer - the connector will charge the battery while in tow and run my winch from the battery on the boat trailer.
4-way is Light Duty. 7-way is Heavy Duty.
I have been a professional Aircraft Electrician since 1958 and I have been wiring trucks for towing rvs since 1972. Trying to connect a 7-way to a 4-way with a battery feed is amateurish, unsafe and unreliable.
Battery feeds are not to be jury-rigged nor tampered with. The ground cable to your trailer has to be the same gauge, or larger than, the battery feed. If you need a 12 volt feed for the battery in your trailer, install a 7-way on your trailer!!!!
The limited amperage cable in you OEM 7-way is intended only for charging the battery in your trailer. It will probably overheat and burn up if you connect it to a heavy load such as a winch.
U-Haul uses 4-ways because they are cheap! cheap! cheap!
I have the OEM 7-wire wiring/plug on my '03 Silverado Z71. For 4-wire equipment, I keep a 7-wire to 4-wire adapter plug in my glove box for use with U-Haul trailers. I just plug the adapter into the receptacle on the truck and the 4-wire connector to the 4-wire side. I don't recall ever using a trailer that required a 7-wire plug... however, I normally rent U-Haul equipment only so that may explain it.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
