chevydriver37 Posted September 22, 2008 Posted September 22, 2008 Hi, Got a '98 Blazer that's in great shape, 70K miles, but needed brake lines all the way around. Got that nightmare outta the way, but now I need tank, fuel pump and fuel lines. Tank and pump are not an issue, but I don't quite understand the fuel lines here. How do you replace the metal lines between the quick connects? Can you cut out the rotted line, replace it with new steel, then connect with high-pressure fuel line/high pressure clamps? The pressure (60-65lbs) is pretty high for that kind of line, isn't it? I tried looking up a part number (or anything for that matter), on a total line replacement, but couldn't find a darn thing. Can you even buy a new line kit? Any suggestions/help/guidance/counseling is greatly appreciated. Thanks
