The 5.3l?
jman_07
So i noticed the Newer 5.3L engines have more horsepower my dads 2002 is only rated at 295 Horsepower how is the new one have more??? I heard they switched to Electric fans or something like that???
Also his 2002 Silverado from a stop cannot spin tires at all the 5.3L seems weak but i heard there is something in the computer that holds it back from spinning tires off the line what is it???
Thanks.
He'll need a custom tune, it's the torque management & other nannies holding him back. For what I've read, the consensus around here seems to suggest going with BlackBear Performance for the custom tune by Justin. I'll be getting one from him next year. Even after the tune, your dad may still not be able to spin the tires, but will definitely have a better throttle-response, increased hp & better fuel economy.
It just seems like 285 Horsepower is really weak for a V8 Engine so i dont know how could i pull 300 Horsepower without spending money on performance parts there is gotta be some little tweaks.
285 horsepower is actually a great improvement over the previous gen engines. The old 5.7L V8 put out 250 hp if I'm not mistaken. Even the 7.4L put out 290hp. The reason for more power in the new engines is because of revised programming and a different camshaft. Also, like someone already said, it won't spin the tires because of the torque management program. If you want to disable that you need to beef up your transmission or you will risk destroying it. 285hp is not weak at all. In the early 2000's it was a big deal if a V8 put out 385hp from the factory(the first Z06). Truck engines are designed for less horsepower, but more torque. Car engines are just the opposite, more hp with less torque. You won't get 300 hp from that engine without spending at least $250-$300. I have an AEM intake and Flowmaster exhaust which brought the power up to about 300. See my sig to read more details.
Another huge reason for the power being seemingly low is thanks to all the emissions regulations. Back in the late 60's a 5.7L V8 could put out 400hp without breaking a sweat.
Every year manufacturers bump up horsepower ratings by 5-15 HP for their engines to stay competitive with other makers and claim to put out the most power.
A late 80s TBI 350 was only rated at 200-210 HP.
I'm willing to bet money that it does. My buddy's 2004 Avalanche has it and it has the same trans.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 626 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
