SES light came on it my truck. Code reader gave me PO430 catalyist efficency below threshold ( bank 2). There is no other codes.
I just replaced the two upstream O2 senors prior to the light coming on. Also noticed a lot of carbon on tailpipe. Truck is a 2002 Sierra 5.3. Thanks.
Where should I start?
