Sierra + Deer = :(
It never fails. Late Summer/Early Fall in Southwest PA + Me driving almost always equals at least one run in with a deer.
Well, before I could get some decent pics of my truck up on here, I have a different variety to show...
I was able to swerve a bit to miss hitting the deer, a buck no less, head on but he still took out a good portion of my front passengers side...
It didnt do a lot of damage but enough to make me cry...lol...
Here's some snot from the bugger:
And dented in the chrome bumper
So I go for an estimate today...hopefully it will look as good as it did pre-deer...
just thought I'd share my unhappiness so you guys could be thankful that your truck is in one piece :)
I really like the truck other than the smashed in front! :)
A good body shop should be able to fix it up as good as new. I've seen a lot worse run ins with a deer than that. Make sure to post pics after you've got it fixed up!
Ouch! That really sucks that you clipped a deer and damaged your truck like that. I'm glad that you weren't hurt. The damage doesn't look too bad. It could have been a lot worse if you hadn't swerved. Hopefully it won't take too long to repair.
That sucks!
Where you live at in Southwest Pa?
Near Greensburg....my father in law used to teach in Carmichaels school district....
That sucks!
Well ain't it a small world!!! :) ....I graduated in 1990,was he teaching around that time?
That sucks!
I'll have to ask him...i want to say he was there during the late 80s early 90s...I'll check with him...
I live in Latrobe, Arnold Palmer's collision is pretty good. They fixed my mother's Charger after it was rear-ended in a hit and run.
Sorry about the damage. It's still better than hitting on on your dirtbike at 45mph. Had that happen to me during a race (Enduro) a few years ago. One blink and the thing went from the side of the road to IMMEDIATELY in front of me. T-boned her good and did a flying superman over the deer and into the road. Saw my bike cartwheeling down the road. Also saw the deer crawling into the woods probably to die guessing from the impact. A split second either way and it would have never happened. Only positive was no damage to the dirtbike. Had some nice chunks of flesh missing on my arms and a ruined helmet but it definitely saved my life as my head hit the pavement HARD. I remember thinking I'd be dead if I didn't have full safety gear on.
Anyhow, good luck getting it fixed. I'm sure she will be good as new.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
