305/50/20 Fit On An Oem 20x8.5
just wondering if anyone has this setup and how the wheels balance out with the wider tires.
That should work although the stock rim is 8" not 8.5". This guy runs 305/55/20's on his stockerss.
http://www.gm-trucks.com/forums/index.php?showtopic=81893
Now, I run 305/50/20's on an 8.5" rim and they work great.
Tobias, are you sure? I had Centerline cut my wheels to exact OEM spec of my originals, and the width is 8.5"
No, I was incorrect. As you can see I edited before you finished your reply.
Any decent tire stores will have a tire fitment guide which shows what size tires are compatible with certain size rims. Just because somebody mounts oversize tires on their rims does not mean it is safe, smart, or recommended by tire experts. I knew a guy who mounted 31X10.5R15 tires on 6.5 inch rims. According to the fitment guide, these tires should be mounted only on rims from 7.0 to 9.0 inches wide.
A 305/50R20 is approved to be run on an 8.5" rim. Don't worry.
    ballencd
    ballencd
  • Who's Online   4 Members, 0 Anonymous, 447 Guests (See full list)
