Lightweight 18's
Looking for some lightweight 18" rims. I have the stock denali 18" right now and would like a better looking wheel and may drop a tire size to save more weight and still look normal after my 2/2 drop I have planned.
I occasionally tow so I dont want lightweight feathers. Thinking center line, are they the lightest weight? Thanks for the suggestions.
Yes, lightest and strongest. Weld Wheels are another good option
Welds are definitely the lightest and strongest. The only problem witht the Welds is keeping them clean looking if you get the polished, the chrome isn't so bad I hear, I wouldnt know. They are alot more. They will be lighter than you stock wheels though.
Thanks guy, the link to the welds is a steal!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
