Build Sheet Request
Hi, I was wondering if someone could post my build sheet. I have a 99 Yukon and I am putting a hitch on it. I was going to put in a trans cooler but it appears that there is one already. Did these trucks come with cooler even without the tow package?
If someone can get a build sheet I would appreciate it!
Thanks!
Danny
It is already equipped with an auxilary tranny cooler.
Awesome thanks!
Any chance I can get a build sheet though??
Awesome thanks!
Well...two things......
First were not allowed to post stuff like that anymore as per GM (Although I did post one a couple days ago :D )
And secondly..For the '99 model year it doesn't give descriptions for the RPO codes,It just list the RPO codes themselves,which you can find in your glovebox.
BTW...."KNP" is the code for the auxilary tranny cooler.
Awesome thanks!
Cool, I'll check it out. Thanks for the help.
Danny
