2006 Gmc Canyon Intermittent Cranking Problems
jason widener
:D This has now occured twice.
It appears that when i crank the truck the engine turns over but either does not have fire or is starving for fuel.
I have fuel at the fuel raid when the scrader core was pressed in on the rail. the only fuel filter is not a externally servicable filter type (geniously placed in tank). 40,000 miles never have had problem before.
After about 5 to 10 minutes of trying to crank the truck, it finally starts.
not under warranty anymore, obviously. No faults picked up on by tester at Advance Auto.
Does this sound like it is the cam position sensor magnet getting dirty and not allowing proper cranking? a buddy of mine told me he has experienced this before. shouldnt be difficult to pull and observe.
But, is there anything else this could be?
Should i be very concerned and take the truck to the dealer?
Honestly this is pretty impossible to answer without any concrete data whatsoever. It could be just about anything. I wouldn't even feel comfortable telling you some of the possibilities because there is really nothing to go on just from your post alone.
Some fuel doesn't equal enough fuel so pressure testing during the event would be a good place to start. I don't know what kind of scanner advance auto has so there could be some modules not reporting data to it, there could be codes that they cannot see.
It only happened 2x but how often? If you can't duplicate the problem it could be pretty hard to find. Sometimes doing snapshots of different operating conditions can point to a problem area but that can take a very long time and even then all we are looking for is anything that doesn't look perfect that could cause that problem. If you can't duplicate it then we could find something that doesn't look right and fix that but you could still have a problem.
My suggestion is to sit down and make a list of what the conditions were when the problem occoured.
  • what was the weather condition
  • how long since the vehicle was last run
  • if it had been run recently how long was it run the previous time
  • what was the length of time between previous run and this failure
  • what did you do EXACTLY to try to start it
  • take special note of condition of all lights and gages on the dash during normal starts, do they react the same when the no start happens
  • pay special attention to the security lamp
  • how long since last fuel fill
  • what kind of fuel
  • what did you eat for dinner
Basically every and any little thing that you can take note of can be helpful so take note of it all. Figure out the condition that matches every time and see if you can duplicate it. If you can then take it somewhere and show them how to duplicate it.
Good luck.
I appreciate your advice.
to answer some of the questions though for info purposes
the truck is used every day and often.
weather the first time it happened and this time was about the same, no real obvious or significant weather conditions, fair i would say.
failures occured one week apart almost down to the same hour. kind of strange.
all gauges, fans, etc. were identical.
ordinary cranking procedures
i fill it up every week with gas from the Hess station. never had a problem prior.
87 octane as usual. filled up with 93 octane about 2 months ago.
i ate shrimp last night. jk
i dont know about the scanner used by Advance, but it likely didnt show cuz the system may had reset itself when i finally cranked it last time.
i have driven it four more times since this today and no problems yet. maybe i will keep going until next sunday at 2 and see if it happens again.
  • what kind of fuel
Good luck.
Good but a little more specific
weather the first time it happened and this time was about the same, no real obvious or significant weather conditions, fair i would say. like here, what was the temperature.
failures occured one week apart almost down to the same hour. kind of strange. HMM probably means nothing but note what time of day was that.
87 octane as usual. filled up with 93 octane about 2 months ago. Don't bother with the 93 it isn't doing anything for your particular vehicle just stick to the 87.
i ate shrimp last night. jk YUMMY :D
i dont know about the scanner used by Advance, but it likely didnt show cuz the system may had reset itself when i finally cranked it last time. No if there were a PCM code set it would not go away that fast, I was thinking it may not read every module like the BCM or other modules that can point to a problem.
Any way you get the point just take some careful note and try to find something that is a common denominator, that is going to help out.
edited for stupid grammar on my part
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
