Lights On The Gmc Sierra 2002
Hi guys,
In Germany the lights are diffrent (in which one is allowed (but I don't care) to be on) than the lights in the US.
If I turn on the lights:
number 1 is on,
number 3 is on,
number 5 is on (because i changed it, before they where off)
If I turn on the day-lights:
number 3 is on,
number 5 is on
Direction Indicators are number 5 & 4 and they change when they are on.
What are the original US-lights? Because I want to have the original lamps on.
Is number 4 a daylight too in the us? And are the direction indicators changing (number 5 & 4)?
I hope everyone is understanding what i mean :thumbs:
#3 are the DRL's (Daytime Running Light) #4 is not
#4 & #5 should change (Blink On & Off) when you have the turn-signals or hazzard lights on.
When you turn the lights on,Numbers 1,4,and 5 should come on (Until you activate your high-beams,then #2 comes on and #1 goes off)
Unless I screw up the list due to lack of sleep. IIRC it works like this.
1 - Low beam
2 - High beam
3 - Daytime running light
4 - Park light
5 - Turning indicator light
Default (no lights manually turned on) would be 3 on
First setting (park lights) 4 (and possibly 5) would be on
Low beams 1 and 4 (and maybe 5) would be on
High beams 2 and 4 (and maybe 5) would be on
Thats correct,Why didn't I list it that way :thumbs:
And 5 should be on when any of the lights are turned on.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
