Fiberglass Lid Storage
Just bought a Sierra, it came with a nice fiberglass lid, but I want to remove that for the time being. I am not too sure on any special way of storing(flat, on side....etc). Any hints. I would like to place leaning on the wall in my garage for now but I have a feeling that you have to keep them flat.
Thanks
My next door neighbor has two hooks on the garage wall that he hangs his flat against the wall on. It works well.
Why do I know this?
He always comes and gets me anytime he wants to remove it or put it back on. It's OK though... he pays up in Shiner Bock and is a pretty good guy.
thanks for the really quick reply....haha
do you know if i can rest it on the side?
Is it a SnugLid? If not what brand?
Most I've seen could be stored on their side without damage. Post a pic if you can.
Well right off it's a Leonard fiberglass with the hydraulic lifts. I don't have pic right off hand and that may take a while since I just dropped mine in the river while fly fishing...so.... sorry don't really know too much about lids.
thanks for the replies though, you've pretty much confirmed what i've heard
thanks
From your description, you should have zero problems storing it on its side. Fiberglass covers are pretty tough. (as long as they don't get blown over)
Good luck!
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,242 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
