Rear Leveling Kit?
Thinking about a 2" leveling kit for the the front of the truck,but I want the back end to sit the same way it does without any leveling kit(as in now..stock).What do you recommend?
Cheers Primo.
Cheers Primo.
Easy. Just add a 3 inch block to the rear in place of the factory block.
Cheers Primo.
What would you recommend that is easy to install & easy on the wallet???
Cheers Primo.
Cheers Primo.
Cheers Primo.
2" or 3" block, depending on how much rear lift you want (stock block is either 1", or 1.25").
For under a hundred bucks you can get new blocks and u-bolts.
Cheers Primo.
Cheers Primo.
DV2000NJ your sig pic is killing me.... no body.... no body can be that happy...
I had just let loose a REALLY big fart. My colon deflated like a balloon, best feeling of my life. :jester:
That pic still kills me! Absolutely a once in a lifetime pic. :)
I still laugh when I see it. Not only the face, but the location just looks so... wrong. People don't belong in there. :)
I just installed a 2" leveling kit and put 2" blocks in the rear. The rear now sits about 3/4" to 1" higher. I think it looks perfect. The factory blocks are either 1" or 1.25".
