I Need A Straight Answer On Install A Gm Nav System
agood1
I have a 2003 Hummer H2 with the Y91 option. I have been researching installing a GM OEM nav system in it...but I cannot figure out which one will plug and play. I get different answers about LUX and NON LUX and Premium and Non Premium.....I just need someone that knows, or has already done this conversion to give me a definite answer.
I have been told I need part 15800000. Is that right? Is this a superceded number? If so, what is the old number.
Thanks
  • 1 month later...
Thanks
if you have the Y91 option which is the LUX bose system you need one of these P/N
LUX Touchscreen Nav 15800001, 15230099, 10377531
LUX Non-Touchscreen Nav 15204335, 15204334, 15108241
the 15800001 is the best of the bunch it is the latest touchscreen revison made so that would be my choice. I am currently doing the same thing on an 03 denali with the Y91 option. I was looking for the 15800001 but ended up getting a smoking deal on a 10377531 radio (first revision touch screen) so thats what I went with, now I just need to find the p/n for the gps antenna that I need and I'm good to go.
Good Luck!!
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 384 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?  Thanks.  I apologize for hijacking the thread
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
