Cooling Problems
2001' Silverado 1500 4wd with a 5.3 liter. It runs fine but it warms up on the gauge to about 250 F. It doesn't feel or seem that its overheating it there an easy fix or do I need a thermostat.
yep, I would recommend a thermostat replacement (as it is cheap) and flush the coolant
You may need a new radiator too. Remove it and take it to a good radiator shop to have it flow tested. ti
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
