03 Denali Questions
Program the seats? Are you referring to the driver memory settings? If so...put the system into whichever mode you want it in, I'm going to assume you want that to be Driver 1 :sleep: .
Put the key in, hit the ignition on or start the engine. Get your favorite radio presets lined up, adjust the climate controls the way you like it, adjust the side mirrors and then finally get that seat feeling just the way you like. When you've got it all correct, press and hold the Memory 1 button on the driver door until you hear a beep BEEP. Now your settings are stored.
As far as the homelink goes...I don't use mine..I don't even think it's been activated before...I could go out and get my manual from the truck, but hopefully someone can give you a quick rundown.
