Message Center Lights/indicator Gmc Truck
I have a question for an expert. i have a 2002 gmc 5.3l sierra. I have a message indicator light that comes on an when i put it in gear it goes out.sometimes just when i drive along it comes on a few seconds an goes out.all it say is change engine oil. i know its nothing serious,and i just had my oil changed 1k miles ago.My question is as a new gm owner(previously ford) how do these work? is that how its suppose to work ? the light come son an goes out as a warning? i always thought when the change oil light came on it stayed on.Just please educate me on how this works.thanks..........ps. my truck didnt come with a manual ,i guess it woulda explained it to me.
ok,I did some research an found the turn the key, press gas pedal 3 times in 5 seconds.it took a couple times but when i restarted the truck the light was not on,so i hope that is all it was
I'm sure it was like an oil life monitor which is set to remind you to change oil at a preset number of miles and you just performed the resetting of it. I assume it will come back on in about 2000, or 2500 or 3000 miles.
I was wondering that myself this week since my change oil light came on too.
Cool license plate in your signature btw....where did you get it? :lol:
I distorted it and didn't even notice the final shape till someone commented on it later. Turned out kinda neat I guess.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
