G80 Engagemnet?
How long is the G80 suppossed to stay engaged for? Mine seems to only work for a fraction of a second. On a slippery surface it goes on and off many times. I think all this engagement/disengagement is a little rough on the truck. I think I may have ruined the T-case mount last night going up a very steep hill covered in wet leaves.
The video does not explain how long it should lock after engagement. Another youtube video demonstating on ice made it seem like it stayed on a few seconds, which is not the case with mine.
It unlocks over 20 miles per hour. There may be a problem with yours.
Don
Don,
Do you mean when it is activated it is suppossed to stay engaged to 20 mph instead of releasing really quick?
Thanks,
Rob
Yes, that would be the way it normally works.
Don
I have 35K on the truck and used Mobil Synthetic 75-90 @30K. The dif. was actually pretty dark @30K. The T-case was kinda dark considering it is a light colored fluid. The front dif. was grey. The brake fluid was black.
I tried another wet leaf hill climb. First I had to wait for an older woman in a Honda who failed to make it and wound-up backing all the way down the hill. If she skipped the stop sign at the top she would have made. I felt the G80 engage and it seemed to stay engaged crawling in first gear most of the way up. Then I stopped @ the stop sign, when I tried to go it seemed that it was trying to engage and just would'nt. It was noisy and went into wheel hop. I hit 4WD to make it and it still had some slip.
The truck has been engaging the G80 in short bursts since I got it, but it seems to be getting worse. When it stops raining I need to check the T-case mount, it is now giving me a clank between reverse and drive. The mount may also explain the wheel hop.
What transfer case position is it in? AUTO or 2wd?
If so its not the rear end its the front axle engaging/disengaging.
PS - I have owned 4x4 trucks for 30 yrs.
I know what your talking about, 4wd Auto kicks in hard (sometimes really hard). But it has been doing the things I described in 2wd. I have owned over a dozen 4wd drive trucks. This is my first with the locking dif. or the auto 4wd. My dad's navigator engauges it's 4wd even harder. The Navigator also has no option to turn it off.
You should feel a clunk as the locker engages within a second after one tire starts to spin. The locking mechanism will keep the diff locked until torque is released. The locking mechanism also prevents activating above 20mph but that has nothing to do with when the diff unlocks.
Don
I had mine in the dealer last week because it wasn't locking up. Come to find out it won't above 20MPH.
What a crock. Just because people don't know how to drive.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
