I do not like the wood trim in the truck. I've been thinking of ordering the parts to replace it with trim aluminum as others here have done. Does anyone know of a company or website where I could order a darker trim set? I'd like to have almost black, brushed aluminum or flat black. Any help would be appreciated.
I've searched here and other places with no luck. TIA
http://www.google.com/search?hl=en&q=g...amp;aq=f&oq=
Try going to a Tahoe forum and asking guys there if they want to trade. I'm sure lot's of guys with LT's want the nice wood grain of the LTZ's and would consider a straight-up swap. Yuk's work too, of course.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
