Actuators.
I found out a lot about actuators. There are a few in Gm trucks. 4 actually. 2 of them cost $300 each the other 2 cost around $80. The cheaper ones are easy to get to. The expensive ones require you to remove entire dash, entirely passenger side. this is for problems of uneven volume of air being blown out driver to passenger side and if temperatures do not blend at the gauge you set them at.
