airaid
JUST ORDERED A NEW AIRAID SYSTEM FOR MY 98 SMC
5.7.    I KNOW I CAN DITCH THE SENSOR THAT IS SUPPOSED
TO TELL ME WHEN THE AIR FILTER IS DIRTY BUT I DON'T
KNOW WHAT THE OTHER SENSOR NEXT TO IT IS.  IT HAS TWO WIRES AND IS PLUGGED INTO THE AIR INTAKE HOSE BETWEEN THE FILTER AND THE MAF SENSOR. I DON'T BELIEVE
THE AIRAID HAS A PLACE TO PLUG THIS IN. ANY INPUT WOULD
BE APPRECIATED THANKS.
That would be the IAT sensor.  Measures the intake air temperature and adjusts the air/fuel mix accordingly.
Be careful not to break that sensor.  They are VERY delicate.
There should be a hole on the Airaid intake tube for this.
I had an Airaid on my 99 Tahoe.  You will need to put this on your airaid setup.
Steve
Hey Speedzone, question for you, why did you chose the airaid over the K&N. I under stand you are putting on 98 and the metal tube of the airaid to me looks better than the plastic that the K&N has but what other reasons. To all, are there any power differences in the two? observation ....Iwhish you could get metal tube set up for 99 plus trucks!!!!
STEVE I INSTALLED THE AIRAID LAST FRIDAY AND THE INSTRUCTIONS TOLD ME ABOUT THE TEMPERATURE SENSOR
BUT THANKS FOR THE ANSWER!
 LIKAROK I CHOSE THE AIRAID OVER THE K&N BECAUSE OF
THE LOOKS BUT ALSO BECAUSE OF THE PRICE. I ADDED TRUE DUALS WITH FLOWMASTERS THE WEEK BEFORE I PUT ON THE
AIRAID AND RIGHT KNOW I AM VERY HAPPY WITH THE SOUND AND THE THROTTLE REPSPONSE. THE K&N MIGHT BE BETTER BECAUSE IT PICKS UP MORE COLD AIR.
