Sister's 2003 Trailblazer Straight 6
dzrick
In case I was to wordy or made this too confusing.
The main question is what controls the idle speed when the AC or defroster is on in a 2003 Trailblazer straight 6 cylinder. I'd really like to have the defroster working in my sisters truck.
The rest below is just what we've done to the truck in the last couple of months in case it might have caused the problem.
This might be a little long but I want to give you all the facts as I know them.
Awhile back, maybe 2 months ago we had to replace my sister's battery due to a bad cell after changing it we found that the altenator wasn't charging so we changed that as well.
Now the facts get a bit fuzzy, she can't remember if the defroster and AC bogged the motor down before all this or not or if she doesn't know because she wasn't using either of these until recently.
I do know that until we changed the heater resistor today that she was only able to use the highest fan speed (5 I believe) but when in the the AC setting and the defroster setting would stall the truck or come close to stalling it.
Now she has all the fan speeds but when we put in defrost or AC it still boggs the motor down sometimes right down to a stall, it'll start right back up but I'm thinking there must be something that idles the motor up when either the defroster or AC is used that isn't doing it's job.
Can you tell me what it's called and where it's located or if my thinking is wrong, straighten me out.
Thank you for any help you can offer,
Rick
Your on track Rick. Definitely the idle-up feature is malfunctioning. I don't know where its located on these all electronic vehicles, other then to guess its all PCM controlled, like timing and fuel injection.
I'm used to the old solenoid vehicle setups. Perhaps someone else on this forum can enlighten us?
Thanks for the bump and I hope someone can enlighten us soon, I may have to let her take my truck in the meantime. (don't want to) :cheers:
There is an IDLE RELEARN procedure that you sometimes have to go thru.
I don't know how to do it.
Post your problem in the main forum and get a lot more feedback.
Thanks Jim,
I'll do that.
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
    • Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive.   I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though.   I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing.   What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament".
