Interesting Video From Ford.....
was that ford equipped with a triton5.4? they probaly didn't used very comparable engines in the trucks, as a 5.4 6-speed shouldn't beat out a 5.3 6-speed unless one driver is flooring it the whole time.
Ford had the 4.6L.
Anyone else notice that they only showed side-by-side comparisons with the Ford and the Tundra? They showed some clips of the dodge and Chevy after the Ford had run, but not comparing it to the Silverado or the Ram?
If you look in the upper left corner, you can choose which truck you are comparing. None of the trucks looked great in the speed bumps. Each had their issues but hopefully Toyota will start making a boxed frame. That thing really looked bad. Even my girlfriend knew that a truck shouldn't twist like that :lol:
Goodness... the Toyota looked almost scary bad with the bad road simulation. Gosh, in almost all tests it looked bad.
