Overloaded Dodge Ram
dietz4ibanez
Brian, you can't carry a boat like that, okay?
Dont laugh at me for trying! Laugh at me for 1. driving a dodge and 2. either not paying attention to the red light or simply disregarding that fact that I am a bad driver and failed to get a brake controller! :bs:
I still have yet to figure out why they let me have a CDL!!! :P
Saw these pictures a couple years ago, but they're still fuggin hilarious.
Well if only you posted them a couple of years ago... Or at least when you joined the site! :bs: let just say I am just now getting through all my old unread e-mails! :P
Brian, when did you get a Dodge?? :lol:
from mommy dodge??? :lol:
PSST! He said when, not where. :bs:
Thanks!!! :P
"Mommy Dodge" isn't a point in time. :P
from mommy dodge??? :D
Thanks!!! :P
Sorry... I was trying to say :lol: about the dodge....
