Ride Rite Kit Problems?
Hi guys, bought a 08 Sierra CC Z71 in March. I set our 24 ft. trailer upto it with 3 sleds in it and took it down the rode to see how it handled. The front end felt very light. I looked around and found the Firestone ride rite, got it in and went to put it on and the upper brackets were to narrow to fit over the bumpstop correctly. Just two points of the bumpstop cup sits on the bracket, these points sit on the radius though so this bracket could actually rock around. Also the part of the bracket that sits on the side of the frame rail is about 3/8 inch from the rail. Anyone have any issues like this? They market this kit as no drilling or cutting required, to get it to work will require some modification. I am very dissappointed with this kit.
Brent
Are you sure you got the right kit? I installed the kit on mine with zero issues. Only thing I did extra was buy a tee fitting to put air in both evenly at the same time.
Was it both sides, or just one. Could be the bumpstop got welded at the wrong spot. Also, you did use the spacer didn't you? The upper bracket should not even touch the cup, just the frame.
Here are the instructions for the 2430 kit for the 2008 CC truck.
Air Bag Instructions
C
Ya I received a 2430 kit and put the spacer in there, however the spacer was loose between frame and upper bracket. I'm thinking of making a new spacer out of a slug of metal to get the bracket off the cup. I still don't like that those vertical peices on the bracket are 3/8 of an inch from the inside frame rail. Was yours like that? Also it seemed like the bag centerline is barely under the frame rail. Not sure if I like that. I hope they will fix the way my front end feels light with my trailer on it.
Brent
You need to have contact on the vertical and the horizontal edges of the bracket. It could be the cup on the frame was pressed too much and is too wide. I would just grind off the sides of the cup untl the bracket will fit against the frame properly.
Remember, there are also 2 holes in the bracket, Try swapping sides to see if that will help.
Here are some photos showing fit against frame and spacer holding bracket off the cup.
C
Oh man, thanks soo much for those pics. that cup shot looked like mine but i looked up at the spacer through the alignment hole and could move the spacer with a zip tie that I poked through the space between the cup and bracket. I think I am just gonna make my own spacer and maybe add some flat stock to the verticals to take up some of that space.
Thanks everyone,
Brent
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
