Audio Experts Please Help!
So I am planning on installing a single 10'' sub into my 08 Silverado Ext. Cab in the next few days. I already have the sub, amp, wiring, and stereo adapter. Now the most important part... the BOX
I know a guy at a local shop who said he would help me build a box. However, I am trying to decide between ported and sealed.
My sub is a FiCaraudio SSD 10. It runs at about 800-850 RMS power. On Fi's site the box requirements for ported and sealed are as follows:
Sealed box: .2-.6 cuft
Ported box: .9-1.5 cuft @ 33Hz
Mounting depth: 6.000"
Displacement: 0.12cuft
Similar boxes from subthump.com are about .9'' cu in volume.
I know its better to be on the higher side of the range to get the best sound and lows. Would it be better to go sealed? I would go with subthump's box, however, I've heard their down firing boxes sound muddy with high excursion, high power subs.
Advice would be appreciated!
-Mike
will all the subs i've had i've decided to do with a sealed box. with ported boxes you can hear the "puff" of air when the bass hits hard. however with ported boxes you get more of a full range of the lower bass. The sealed boxes hit hard, however you loose some low end bass. Since its only a 10" id just mount it regularly. best of luck.
x2!
SubThump :sigh:
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 242 Guests (See full list)
