Noob Question: Feasible To Install Center-locking Diff?
Hi,
fairly new to this forum. I recently picked up a 1997 K2500 SLT - great vehicle, except it doesn't have a locking center differential which I would have really wanted.
So, is it feasible (I don't say "possible" because really anything is possible, but sometimes the $$$'s involved don't make sense) to install a center differential?
I figure since it was a factory option for 1997 it should be doable to install one.
Assuming it is feasible, what is the consensus of experts on this forum - find a used factory center differential, have it serviced / rebuilt, or go with an aftermarket brand? If the latter, which brands are considered worthwhile spending money on.
Thanks in advance
/alex
Center differential? I assume you mean the rear differential?
The cheapest way would be to find one from a salvage yard. Buy the complete axle assembly and just change it over. I have had new trucks changed over to locking diff, when they were not that way on the lot. I had the dealer do it, cost me about $400 for the unit and another $200 to install, on a 1500.
You will get varying opinions on after market units BUT decide what you want it to do with it. Buying one designed mostly for off-road use to only drive on highway will have disadvantages. The stock GM unit is very good for highway use.
Thanks for the reply.
I actually meant locking center differential, which I thought was a factory option. Your point about staying "application-specific" is well taken. Truck sees mostly winter usage in the snow and relatively little highway use. I have a steep driveway to tackle and when it gets snowed in, I am finding that even in 4LO I get the rear tires to spin while the fronts don't turn much. I really want to be able to lock all 4 wheels together just to tackle a steep hill.
Feel free to correct me if I have my terminology wrong, by the way. And I do appreciate your comment on a locking rear differential. Do you happen to know what the RPO code on that is?
Thanks
/alex
G80 is the rear locking diff, and front lockers aren't recommended as you will not be able to turn very well...I'd either upgrade the tires with studded treads, snow chains, or plow the driveway more often.
You're either talking about the front differential or rear differential. There is no 'center' differential. If you're talking about the rear, I'd go with the Detroit Tru-Trac instead of the GM G80 Gov-Bomb. If you're talking about the front, I wouldn't advise putting a locker up there. When you turn, the inside wheel will start to bind causing things to break since both wheels want to turn at the same speed when the differential is locked.
Thank you for clarifying about there being no 'center' differential - I was severely misinformed.
I checked the RPO codes in the glove box and it DOES list G80 as an option.
I am confused though - I had read (elsewhere) that G80 can refer both to a limited slip - non-locking rear differential or an Eaton G80 locking differential. Am I wrong about that too? Truck is a 1997 K2500. If I do indeed have a locking diff, I suspect it may not be working any longer (bought the truck with ~130K miles on the odometer). I had read that when the G80 units go bad, more often than not they stayed 'locked up' rather than failing to lock. The reason I say that it may not be working any longer is that the right rear tire spins while the left one doesn't seem to turn.
Thanks for all the help and advice.
/alex
/alex
I believe, not positive, but I believe that the G80 code referencing a limited slip is in vehicles other than a fullsize truck (like a car :fume:).
Now I can be corrected if I am mistaken here. If you jack up the rear and turn one of the tires, if the other tire turns the same direction, it has a locking rear. :D
--Mike
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 587 Guests (See full list)
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
