Rear Window Wiper
Had a wild hair during the last snow storm...has anyone ever considered adding a wiper to the one-piece, rear window of their p/u? That's a feature I miss from my previous suv's.
nope!
Do you have a rear window defroster? Even after a ice storm when i turn that on i have no trouble seeying out rear window. And because the window goes straight down water beads right off.... I also do rain-ex all my windows including sides and rear.... And that helps !
If you were to add a wiper the size of it could only be like a 12" at most i would imagine since by the time u factor in the arm and rotation , It will hit.. It wouldnt be worth the hassle IMO.
+1
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
