The Dreaded "service 4x4" Message
I've started getting "Service 4x4" on the DIC on my '05 Tahoe. Today the indicator switch said the transfer case was in neutral, but I was driving so I know that wasn't true. I stopped, turned it off, and restarted it, and was able to shift it back to 2-Hi.
I've only had the truck for a few months, but I do have the warranty claim history on it. Almost exactly every 20,000 miles it's had this warranty entry:
"B K4124 - SENSOR ASSEMBLY, TRANSFER CASE RANGE SELECTOR - REPLACE"
It's now almost exactly 20,000 miles since the last entry so I'd say it's a safe bet that it's the same thing again.
I have 2 questions:
1) What exactly is the part this refers to? Is it just the switch on the dash or is it a part on the transfer case?
2) What if I don't fix it for a while - will it cause other problems or become undriveable? I'm not planning to use 4x4 any time soon.
Thanks in advance! :thumbs:
Does anyone in the day crowd know what part this warranty claim entry refers to?
I would say that either the sensor itself for the 4WD system was replaced or the switch, but I would have to say sensor because if it was the switch, it would probabaly say selector or something like that
RICH, (MS3DALE) would be able to tell you exactly whats up based on that warranty date.
Ah, well if the claim dates help, it's been replaced on the following dates:
10/14/2005
07/06/2006
05/30/2007
10/31/2007
VIN : 1GNEK13T35R211862
I have 2 questions:
Thanks in advance! :lol:
It is just what it says (Not to be smart) The transfer case range selector sensor,It is a part on the transfer case itself,Its actually mounted inside the encoder motor (which is on the transfer case)
Heres the line comments from one of the repairs on your truck...
GM Vehicle Inquiry System
Line Comments
LINE COMMENTS
Repair Order Date : 07/06/2006
Repair Order Number : 136349
Odometer Reading : 28751 miles
Serviced By :
BROWN AND BROWN CHEVROLET, INC.
145 E MAIN
MESA, AZ 85201-7466
Cycle Date Cycle Nbr Case Type Labor Operation Part
07/11/2006 707 01 # K4124 - SENSOR ASSEMBLY, TRANSFER CASE RANGE SELECTOR - REPLACE - PART#88962315 - SENSOR
Comments C-S SERVICE 4X4 LIGHT IS ON AND STABILITY TRAC MESSAGE IS ON. CK FOR CODES CO327 PERFORMED DIANOSIS REPLACED ENCODER MOTOR SENSOR NOW OK
© 1998-2005 General Motors Corporation. All Rights Reserved.
Thanks for the reply Rich, I don't have the line comments on my report. So I would just ask for a transfer case range selector sensor? I can't repair it just yet, but I'm getting prepared. Do you know if it will cause any problems to keep driving it like this, or can I just continue to acknowledge it whenever it pops up?
Thanks again.
Just give them the part number.....88962315.
As far as driving it,I think you'd be OK as long as you don't need four-wheel drive,Although I can't swear to it.
Have you tried putting it in four-wheel drive?
I haven't tried putting it in 4wd since this started. I'm afraid it wouldn't come back out.
Yeah,I know what you mean.....Personally,I'd try out the 4wd though and see what happens.
Maybe Super Stealth can chime in,I see you lurking down there :lol:
I probably would, but I really need it to get back and forth to Tucson every day right now.
Yeah I understand,Its a little easier for me to "take a chance" and try something like that out though,since I work where I work and have access to techs.,a lift,and a TECH2 scan tool! :lol:
You know whats funny (Well its not,but you know what I mean) This will be the what,4th one replaced? Seems like something else is causing that sensor to go bad.
Question is,What? :lol:
Fifth actually (in 76k miles), and it would be nice to find out why it keeps going out.
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
    • Sierra HD Pro:   - If you want a power driver's seat on the Pro, you can't get it.  You have to go to SLE.   - Factory remote start?  Can't get it on any of the Sierra Pro trim (1500 or HD).  You have to go SLE.     - 7 inch radio has limitations for replacement if you wanted to upgrade the screen, etc.    - Steering wheel radio controls?  Nope.  Can you add them?  Yes.  NOT CHEAP.  Requires a new instrument cluster, steering wheel and wiring harness mod kit.     - Fog lights?  Nope.  And no factory path to install them.    Sierra HD SLE:   - IMO, the larger radio screen is a much better interface.   - Fog lights?  You can get them.  Steering wheel controls?  Has them.  Remote start?  Yep.  Power driver seat?  Available.       Silverado WT:   - Same as the Pro above however you CAN get factory remote start installed at the dealer for the WT Chevy.     Silverado Custom:   - Comes with 20" wheels only.  Can you swap later?  Sure.  But.  Truck is calibrated for the stock 20s (34" tire) and no path to properly recalibrate.     - Power seat?  Yes.   - Steering wheel controls?  Same as the Pro above.  No but can be done and not cheap.     Silverado LT:   - Same as the SLE.  You can get or it comes with many features you can't do on the lower trims.       I'd say its all going to come down to what you NEED and what you WANT to have that you'd benefit from.  For me, things like power seat is a must (I hate the WT/Pro seating position), so I'd have to go Custom, LT or SLE right out of the gate.  Steering wheel controls?  Should be standard in 2026 across the board IMO, so again, puts me to LT or SLE.
    • I have a 1500 but the Custom trim. I bought it solely for the simplicity meaning less electronics. I also love the old school gauges. The only thing that I like about the LT better than my Custom is the front grill. Otherwise, absolutely no regrets choosing this trim.
