Gm Front Axle Leaking
I have a quick question. I am working on a 79 (ish) Chevy 1/2 ton 4x4 front differential. Gear oil appears to be leaking out of the passenger side axle tube when I drive the truck with the hubs locked. I am pretty sure the breather is clear. The oil level is about 1/2" below the fill plug. I am thinking the inner axle seals??????
1) Any tricks on removing the differential besides making sure the caps and spacers go back into the same location?
2) I guess I have to punch out the old seals. Any tricks on getting the new ones in?
I have removed front axles already to replace u-joints but never oil seals.
Could this be anything else???????
If the oil is coming out of behind the u-joint, as i understand it, then yes you need to replace the seal and if you want to do even better, replace BOTH seals and you won't have any more problems for a looooooong time!!! :confused:
