Tahoe 2008 4x4
Start by using electronic cleaner and clean connector at the throttlebody & accelerator rheostat and also clean all grounds on chassis,engine and in cab. Most common problem is corrosion at connectors and grounds. Use the FSM to locate all the grounds & connectors and go through the P2138 diagnostics before replacing any parts.
Take it in under warranty.
+1 If it's under warranty, take it in. Then any repairs needed will also be covered under warranty as well.
Clean all of them when in doubt. Cant hurt.
HI JIM THANK YOU FOR YOUR RESPONSE, I THINK YOU TALKING ABOUT IT IS CORRECT BUT WHERE IS THE connector on the Body Control Module. THAT IS THE ANOTHER SIDE WIRE?
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 590 Guests (See full list)
