Fs: Isimple Pghgm5
I bout the iSimple from Peripheral and installed it in my truck this past week. The iSimple comes with 2 wiring harnesses, and you use one of them based on the GM vehicle you drive. So now I've got a wiring harness that I'm not going to use. The kit came with a box to mail back the unused harness "for recycling", but they're asking me to pay for postage. I know, its a couple dollars but I think it's just tacky they didn't include return postage.
I figured before I shipped it back I'd offer it on here to anyone who wants it. I'm not looking to make any money off of it, so I'm asking for enough to pay for shipping to whoever wants it. Let's say $5 for regular shipping, and $10 if you want it priority/overnighted.
Keep in mind that this does not include the PXAMG module OR the iPod cable that runs from the PXAMG to the iPod. I'm not going to try to rip anyone off by any means, I think buying the iSimple kit is cheaper than buying the harness, cable, and module online, but if you had access to one of the others cheaper than retail then this might be for you.
Here's a link to the vehicles supported. Look for yours and see if it uses this harness.
http://www.discountcarstereo.com/pdf/pxamg.pdf
Here's a picture of the cable
I'll keep this up for a week, then I'm going to mail it back to the manufacturer.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
