Congratulations Go Out To The Pittsburgh Seelers
2000DV4.8
Unbelievable game!
I still think that last fumble should have at least been buzzed for review by the booth but even if it had been overturned, the Steelers likely would have won anyway.
Congrats Steelers!
-Frank, A Myopic Cowboy's Fan
And the REAL winner is........
The Bud Light commercial where they threw the dude out the window from several stories up, toward the beginning of the game. :D:D:crackup:
That was good, and I liked the one for career builder with the lady screaming, the guy getting yelled at in the cuibicle, the guy on the whale or dolphin or something, the guy crying at the bus stop, the guy punching a koala, and the guy with no pants on clipping his toenails in a cubicle.
The baby investor ones are always classic, as are the Clydesdale ones. I liked the one where the horse brought the guy the huge branch.
Yeah, but overall, the ads were a disappointment. They seem to be getting worse every year.
I donno, I thought they were better this year than in the last couple years. :D The commercials in the first half were a LOT better though.
Yea, if anything, Ariz scored too quickly on their last TD drive... but you have to give Pitt credit for driving down the field for the final score.
For awhile there, I thought my prediction of an Ariz victory 24-20 would be pretty accurate. Damn! :D
We was robbed!!! Oh wait I didn't care who won. Just with everyone you heard talk about the Steelers I just needed to pull for the underdog's. :jester:
I didn't see a single down of that game. First time I haven't watched at least part of the Stooperbowl since the 80s. I'll just watch the commercials on YouTube tomorrow.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
