Leveling And Lifting 06 1500
New here so excuse my ignorance. I have a 2006 GMC 1500 4x4 that I would like to level out and maybe put about a 4" lift on. I was reading about springtech and rough country spindles, but can't seem to find if these work on the 4x4. I would like to keep the rear end a little lower than the front because I like the look. Any suggestions?
If I were to get the pro comp leveling kit then crank up the torsion bars will that give about 3" of lift or can I not do both?
Getting a leveling kit on a torsion bar suspension is the same thing as just cranking your stock keys except you can go higher with aftermarket keys. To be safe, limit it to a 1.5" of torsion crank. You can achieve this with your stock keys. Going more than 1.5" will cause your front end parts to wear unnecessarily fast and could cause an accident.
If i were you id buy a Dodge :angel: They dont need all that work!
If i were you id buy a Dodge :D They dont need all that work!
i have a rough country on mine if i can put it on anyone can :angel:
if i had more balls id put a 4in on mine???
