Suspension Lift
I was wanting to know if anyone found a way to get the 3500 1ton dually off the ground with a suspension lift. It is the old body style. I spoke to 4wheelparts about what I could do, but they said my truck model fell in between the cracks. I dont have the tortion bars for the key lift like the new body style is and they said that the 99 model coil spring lift system wouldnt work. I could possibly use the coil spring spacer to just level it , but that is about all I can do besides just doing a body lift. Has anyone done a suspension lift on their truck 3500 1ton dually old body style) and what did you use?
Hopefully someone here can help you out. I did a quick search and as you have found out, the only kits I see are for 2001.
Never done one on a dually, but I would think rancho or pro comp or someone would make a kit for your truck.
I ckecked everywhere Fabtech Rancho so on and so forth. Nothing Thanks for all your help
