Zen Thoughts For Today
dlstewart01
1. Save the whales. Collect the whole set.
2. A day without sunshine is like ... night.
3. On the other hand, you have different fingers.
4. I just got lost in thought. It wasn't familiar territory.
5. 68.7 percent of all statistics are made up on the spot.
6. 99 percent of lawyers give the rest a bad name.
7. I feel like I'm diagonally parked in a parallel universe.
8. Honk if you love peace and quiet.
9. Remember, half the people you know are below average.
10. He who laughs last, thinks slowest.
11. Depression is merely anger without enthusiasm.
12. The early bird may get the worm, but the second mouse gets the cheese in the trap.
13. I drive way too fast to worry about cholesterol.
14. Support bacteria. They're the only culture some people have.
15. Monday is an awful way to spend 1/7 of your week.
16. A clear conscience is usually the sign of a bad memory.
17. Change is inevitable, except from vending machines.
18. Get a new car for your spouse. It'll be a great trade!
19. Plan to be spontaneous tomorrow.
20. Always try to be modest, and be proud of it!
21. If you think nobody cares, try missing a couple of payments.
22. How many of you believe in psycho-kinesis? Raise my hand...
23. OK, so what's the speed of dark?
24. How do you tell when you're out of invisible ink?
25. If everything seems to be going well, you have obviously overlooked something.
26. When everything is coming your way, you're in the wrong lane.
27. Hard work pays off in the future. Laziness pays off now.
28. Everyone has a photographic memory, some just don't have film.
29. If Barbie is so popular, why do you have to buy her friends?
30. How much deeper would the ocean be without sponges?
31. Eagles may soar, but weasels don't get sucked into jet engines.
32. What happens if you get scared half to death twice?
33. I used to have an open mind but my brains kept falling out.
34. I couldn't repair your brakes, so I made your horn louder.
35. Why do psychics have to ask you for your name?
36. Inside every older person is a younger person wondering what happened?
37 Just remember - if the world didn't suck, we would all fall off.
38. Light travels faster than sound. That is why some people appear bright until you hear them speak .
38. Light travels faster than sound. That is why some people appear bright until you hear them speak.
Absolutely excellent and totally true.
:seeya:
Boy I wish I could remember more of these...must be out of film. :)
Mark, you must be one of those with a photographic memory, but with the lens cover glued on... :crackup:
:dunno:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
