I have an 05 silverado. My problem is that the blower doesnt blow when its all the way up at 5. The heat works fine and it works 1 through 4 but when i go up to 5 i hear a click under the passenger side dash and it shuts off. go right back and its on. I just did a engine and transmission tune on the computer. Is it a coincidence that it doesnt work now? could it have something to do with it? Seems a bit strange.
Sounds like the blower motor resistor has gone bad, a common problem, and easy to fix. It is also just coincidence with the tune.
just found the bad resistor. Thanks. Im going to need a new pig tail. Is it a matter of just splicing on a new connector? and whats stopping it from happening again.
Did it Jarod, search this site, a guy put up a nice picture by picture replacement. I didn't need the pigtail my connection was fine. By the way my truck is also an 05. Was a few months ago. Good luck, Jake.
Mine just started doing this the other day also... I am so tired of replacing these things. Seem to only last about 1.5 yrs. or so.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
