Speed By Spectre
There's little actual difference from one cold air intake to another, other than looks. There 3 types of intakes, hot air (air from engine compartment = not good), warm air (mix cool and hot = better), and cold from the fender (best). The GM OEM intakes are cold air intakes. Put in a higher flowing filter and remove the resonator chamber and you have what an aftermarket intake will give you (besides the look).
the shielding looks a bit scrappy. but, that intake will achieve everything a K&N or the like will, for $200 cheaper. Worst case scenario, change the filter on the end to an AEM or other dryflow filter and you're still $150 ahead of one of the other intakes. this actually might not be a bad alternative to the EXTREMELY over priced name brands
Where is the resonator chamber located? I have a K&N filter in my OEM box and i'd like to give this a try before buying a cold air intake. Thanks for the help.
for that, you would do the partial intake kit (just the tube from filter housing to TB) if you look at your intake tube, you'll see a big box atatched to it. That's supposed to baffle the engine sound a bit and supposedly robs some HP. I am going to do the tube myself at some point too.
Brian
Brian
I figured that was the part mentioned. I had checked that out and it looked like it would hurt air flow.
I did my CAI with just the Airaid MIT and a AEM dryflow replacement filter. Total cost around $150.
Yep, You just need the Airaid MIT smooth tube from the stock air box to the TB. The stock paper filter can flow plenty of CFM's for these motors at 6500rpms. A K@N filter in the stock box in my old 420rwhp LS1 Camaro SS was only worth 2 rwhp vs the stocker. That's well within dyno variance so it could have really been worth nothing. A stock Gm truck with 250-280rwhp is not going to even start needing more CFM than what the stock filter can flow.
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
