2002 Z71 Transmission Issues
Driving home from work tonight, pulled out in fast moving traffic and got on the gas pretty good. All of a sudden, the truck felt like it went into neutral, engine revved up, i let off the gas and then it went back into gear with a hard slam. I continued to drive 5 miles home at a slower rate. Now i don't have overdrive, no reverse and maybe no second gear (not sure, from a stop the rpm's rev really high then it shifts into the next gear, assuming third). I did a brief search on this site and saw a similar problem and it was caused by a broken sun gear??? Then the owner only had first and third gear, which i think i have?? What the heck is a sun gear??? The truck is a 2002, (bought in Aug 2001), Chevy 1500 Z71 Extended Cab, short bed, 5.3 L engine, with 155,000 miles & original everything. I am very particular with preventive maintenance and change oil and filters like clock work. Every time i change the oil (5,000 with Mobil 1) miles, i also pull the plug on the trans and drain and replace approx 3 qts of oil. I change the trans filter every 50,000 miles (using oem Delco parts) and just changed its about a month ago. Its mostly a highway driver, to and from work or sports. Not much towing (small boat and motorcycle trailer) and don't use 4x4 very much here in Texas (a couple times a year). I'm pretty sure i need to take it to the shop for a tranny rebuild but would like to know if my assessment is correct and if there are any other options i have. I plan on keeping the truck for several more years and don't want to jeopardize the quality of cheap rebuild with longevity. I don't race and don't need a shift kit or other performance item, just a good transmission and/or rebuild. Would it be worth my while to get some Vaseline and head to the dealer for a fix ($$$$ ouch, my A$$ hurts already just thinking about it) Any help you can provide would be appreciated. Thank you.
Sun Gear assy (typical)
I would have it towed to a good transmission shop for an estimateed cost to repair. Dealership rebuilt trans will be very expensive and is no better than having a good shop do it for a lot less money. Ask around your area and see who is reliable and trusted. I'd stay away from the national chain tranny shops myself...
Check with your local Chevy dealer anyway. Their quotes may be competitive and some dealership have techs who specialize in transmission rebuilding. WE have a local GMC dealer here that rebuilds transmission in his shop and I believe he is pretty reasonable.
Not a bad suggestion. I'm not anti-dealer. It's just that ours want about three times what a good shop wants for rebuilds. They don't do it in house.
Look around for tranny shops or race shops that rebuild transmissions. You should be able to find a shop that can rebuild it, or swap it out - but they ain't cheap. Like others aid, also check with the dealer - a standard GM rebuilt probably isn't going to be cost competitive, but the dealer might be.
Normally, I would go with a GM rebuilt unit but these are different times, your warranty might not be valid in a few weeks after they file. Go to an established trans shop.
Why would filing their taxes affect our warranty? :dunno:
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 678 Guests (See full list)
