Anybody With Carfax
If anybody has a carfax account. Can they run this vin for me. it is 2GCEK19T1X1168988. I ran a history report through autocheck.com but they didn't give me the options that is on this truck. Just wondering if carfax does that or a different website can do that for me.
Also, they said the odometer was replaced and now has 60,000 miles on it. The last time it was titled it had 99,000 miles on it. Who knows how many miles is on it now. Any advice?
Carfax doesn't list anything but the VIN. No options. Just partial history.
That truck is:
VIN 2GCEK19T1X1168988
Year/Make/Model: 1999 CHEVROLET K1500 SILVERADO
Body Style: 3 DOOR EXTENDED CAB PICKUP
Engine Type: 5.3L V8 MPI OHV
Manufactured In: CANADA
So, without knowing the actual mileage on this truck, does $6000 sound like a good deal for a 99 chevy ext cab with 4 wheel drive?
If it's in pretty good condition 6G isn't way out of line but I'd probably keep looking myself unless it was really really nice. Better deals are out there.
The one thing I am worried about is not knowing the actual mileage. I did call the guy and he said it did have some rust on the corner of the cab, but he is fixing that.
Mileage is important but to me condition is MORE important on a 10 year old truck. How well maintained and how well kept are everything once a vehicle is over 5 years old.
So, would you buy something that you didn't know the actual mileage and you was buying it from some guy you didn't know and you don't know how well it was taken care of?
Absolutely NOT!
Maybe if it was 3 grand...
Well, I am going to ask the guy to find out the mileage before the instrument cluster was replaced, so I will go from there. I decided I better pass on it, unless he can get me the mileage that the truck had on it before the cluster was replaced.
That would cause me to walk away regardless of the price and regardless of how good the repair might be. Too many other vehicles out there to choose from. I'd forget about this one and move along.
If you haven't seen the truck or driven it, I think it would be wise to pass. One scary part is "fixing the rust on the corner of the cab". Is it a rust-thru or surface rust or?? Chances are that if rust appears in one spot, it will appear in others.
Lots of other trucks out there for good deals; it just takes some searching.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
