Opinions On Cooper Discoverer Sst
Experience?
Miles?
Faults?
Better tire?
I now have about 70k miles on a set of BFG A/T KO E-rated 285's. I am looking for a replacement.
I have the exact same tires/size/load rating on my truck. Stick with them. Had FS wilderness at, GY wrangler at/s. Firestones lasted, crappy traction. Goodyears lasted, road like sh** and wore even worse.
The only drawback of the A/T is the tendency to clog/load-up, especially at less than full tread.
I was thinking of the M/T's as well, something more aggressive.
I get a lot of my miles on the highway, but it seems more and more often, I am on looser job-sites, whether they be clay based or sand.
My A/T's will still pass inspection, and I would like to change them out, store them, and reinstall them when I sell (keep the newer tire if I like it).
The Cooper tire will not last near as long as a BFG.
A buddy bought KO's the same time I bought Cooper Discoverer AT's Mine are still ok, probably replace them in the fall, he had to replace his 2 years ago. We drive about the same mileage. He did not buy the KO's again.
Cooper Discoverer SSTs are awesome tires. I've got a little less than 20k on my set and they still look basically new.
A relative just put the SST's on his 03 Chevy, but he changes tires often, so I cant put much stock in his opinion. They do look good though. About $50 more per tire too.
Hey check theses out , ive installed a couple of these on some customers trucks, they ride a little bumpy and seem to only be made in bigger sizes (as in wheel sizes) .
But really looks good and have a realy aggresive bite on the road. We put them on a 04 truck with a 3" leveling kit and looked awsome.
VT_Z71 - love the look of your truck with the new rancho lift. How is your ride and gas mileage doing so far? What did you decide as far as tire size, are you gonna go for the Cooper 295's?
Hey.
My mileage has stayed the same since putting the lift on. I kept the same 33" STTs I had with my leveling kit, so mileage has not suffered just by going up. As far as ride, it is definately superior to stock. I have all 4 of the shocks set on Level 5 (out of 1-10) and don't have any need to alter their settings at this point because I'm that satisfied with the ride.
With my tires, I'm fine with the look of the 285s on there now, however, I'm eyeing a set of 295 STTs or possibly a set of 305s (which would have to be another brand mud terrain tire due to available sizes). I've gotta be careful though. With the stock wheels @ 5.5 backspacing, the inside sidewall of my front tires are awefully close to the new Rancho steering knuckles. I want to utilize my stock wheels if at all possible (I just love the look of lifted stock) so I will have to coordinate and make sure 295 or 305 tire sizes won't be too wide that they interfere with the Rancho knuckles.
But, I've got 3 different parties interested in my 285s, which like I said have worn excellent and look almost new. So basically for a few hundred bucks I can go up a size or two and get all new.
I would agree with you there about mine, couple hundred under 20k right now and still look pretty new.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 462 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
