Battery Issue
My truck has been sitting since Aug in my grage. I did drive it for 2 weeks while I was home in Nov. My wife went out to start it and she said it sounds like the battery is dieing again. She starts it once a week. Any ideas.
today she let it run for 30 min to try and recharge the battery. If I had to guess she lets it run for 5 to 10 min on most weeks.
could be loose terminals up to bad alternator.
check terminals first and not sure on a GM but a BMW i've owned before would start and run but would not hold charge, which is your worse case scenario.
That battery tender sounds like a good idea...thing is that just starting the truck and letting idle for 5 to 10 minutes will cause to drain the battery instead of charging it, the alternator charges the battery when the truck is running.
