Silverado 1500 2wd No Parking Lights
I have an issue that I cant trace, my dash lights and all my parking lights are out, my turn signals, headlights, daytime headlights and brake lights all still work, I have tested every relay and every fuse on the truck in all 3 fuse/relay locations anybody out there been thru this? any suggestions? thanks
If you turn the lights on using the switch do the park lights flicker at all? What happens when you cover the light sensor in the middle of the dash? Do the headlamps still come on automatically?
In addition to checking the fuses, pull them and make sure they are firmly seated in the plugs. I've had issue before where simply pulling out and then putting right back in the same fuse ended up solving my problem(don't ask me how). :seeya:
the headlites still come on automatically but I have no parking lights or dash lights I am pullin' my hair the rest of the way out trying to trace the cause, could it be a realy in the bcm?
  • 1 month later...
  • 1 year later...
I have 2001 silverado 4x4 with the exact same problem.
