Anodize Readylift Leveling Kit
I want to get the ReadyLift 2.25" leveling kit and install it, but first I want to black anodize it. Anyone have this done? Any advice about having this done? I think it would look much better to have that spacer match the frame color than stick out by being aluminum. Thanks.
Hit it with a good coat of black spray paint. Anodizing is overkill for that spacer.... And you'll probably scratch it and end up spray painting it anyway
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
