1972 C30
sericjnr
Hi guys, I'm looking at buying a 1970 c30 stepside..Mainly because it's quite cheap and it's already here in Australia and is a right hand drive. My question is to anyone who had/had one. I know that being a c30 these trucks have heavier springs, chassis and running gear, but are they still light enough and do they handle well enough to drive long distances as a daily driver? Most of my driving would be without a load in it, but I sometmes tow a double axle trailer with around 4000lb in it. Is this truck for me or should I hold out for a c10 and put a set of air bags in it for when I tow?
Thanks, Mik
It'll ride like a buckboard,or put about 1,000lbs. in the bed :lol: What size engine? 350?
yeah, with a 4 speed stick shift... very clean body though.. that's what appeals.
It would be pretty easy and not too expensive to swap front coils and rear leafs if it was way too rough riding, not much more than putting bags in a C10.
I've owned about a dozen of that body style over the years, the C30 will ride rough. It will not be easy to find rear leafs for a C10 since they were special order for those style trucks, 98 % of the C10's had rear coil springs and trailing arms. You could remove a couple of the leafs and/or have a spring shop De-arch the leafs to soften the ride but you would also affect your weight carrying capacity. Adding some "ballast" to the bed would be easiest, you may try LMCtrucks.com. They carry just about everything for those model trucks, not sure if they ship to Aus.though. Changing front coils wouldn't be hard at all however. Either way those were great trucks, hope you get it enjoy it. :D
WOW. A C30 is a pretty heavy duty rig to drive daily. One thing that comes to mind is that a truck that has had that many birthdays may be something well beyond what it was when new. I guess a test spin is in order there. Good luck man!
I would expect it to be a little unrefined, considering it's age, but late model trucks like you guys have are up around $90K. ie '05 Avalance $75K.. This makes my old '97 4x4 look pretty appealing and the c30 at $10k asking look pretty reasonable.. I'll see how it goes.
It has probably had some of the starch leach out of it with time. If not I agree with adding some ballast. For an Aussie, your daily beer ration in the rear aught to be sufficient. :D Treat us to a picture.
Definately a tank. :D
I spent hours and hours and thousands of miles in a 1971 C30 Tow Truck my Dad had. These trucks are solid as a rock and although stiff, not nearly as stiff as today's 1 ton trucks. Of course with ours being a tow truck, it had significant weight on the back simply from the bed, winch and boom. I have a friend who farms kind of "old school" and one of his primary farm trucks is a flat bed 1972 C 30.
Of course you can see from my Avatar that I am just a little partial to this body style. :D
    MANGOAL
    MANGOAL
  • Who's Online   6 Members, 0 Anonymous, 545 Guests (See full list)
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
