7 Pin Plug, No Power To Backup Lights
bmklawt
Hello,
First post, I am happy to have found this forum, I have a 2005 Silverado and this is the first time I have had any trouble with it.
There is no power to the backup light pin (center pin) on the 7 pin trailer connector when the vehicle is in reverse, everything else works right. Am I missing something, I can not find a fuse for the backup lights or is is something else.
The reverse lights on the truck work fine.
Your help is much appreciated.
Hello,
It should be the light green wire. I can't recall, but I dont think it is the center pin.
:dunno: I thought the center was ground
I dont think that is correct either. I thought it was for aux power(12+Red). :lol:
FWIW, I just wired up a connector to use in my bed to pull a gooseneck. I had a hell of a time trying to get it to work. Almost every diagram I found online was incorrect. The easiest thing for me to say f' it and get the 'ol DMM out and verify each pin out. I dont recall where the pins were located but I do remember which color wires went where. You may have to do the same.
The center pin is the back up or aux pin most of the time you have to wire it up as it is a aux pin. The back up light wire will be a lt green wire most of the time. pin 1 is the ground usually wire wire, pin 2 brakes blue, pin 3 tail lights brown, pin 4 12v black, pin 5 left turn yellow, pin 6 right turn green. Hopefull this helps.
Thanks everyone for the help,
The center pin is the backup lights, the cover of the trailer 7 pin connector has the pin out molded into the cover.
I finally found the wiring schematic for the trailer wiring in the service manual and it does show a fuse for the backup lights under the hood. There is no mention of trailer wiring in the index of the service manual so I went through 200 pages of print twice and found it.
I went back under the hood and found fuse "TRL B/U" that makes perfect sense now.
I had checked that fuse earlier and it checked good, I also had looked in the owners manual for the fuse description but must have missed it, it is there.
When I check the fuse earlier with a fuse checker it checked good, after finding the info in the book I went back to the "TRL B/U" fuse and actually pulled it out, it looks good so I tested it with the fuse checker while holding it in my had and found that there must be a break in the fuse, it would show good intermittently, the fuse is not blown.
I think when I pressed the pins of the fuse checker into the fuse it would move it enough that where ever it is broke would make contact and show the fuse a good
I put an ohm meter on the pins of the fuse and it read open and when I jiggled the pins of the fuse just right I could get a good reading so I replaced the fuse and all is well.
10 hours of my life down the tubes because a fuse was bad
