2003 Audio Aux Input
Hey guys, I've got an 03 with the CD/Cassette headunit and Bose speakers. I'm looking at a PIE adapter for an aux input, but there are two types of headunits: GM9 and GM12. From what I've gathered, the GM9 are the older units without an external output to XM/CD changer, where the GM12 have these outputs. On my headunit, I do not have an AUX button, it is instead the cassette function. Anyone done this before?
On a side note, is there any way to break up the fullsize forums into two sections, the GMT800 and GMT900. With the two combined, it makes searching nearly impossible. Thanks.
Has been discussed and voted on, was decided to keep in 1 section.
Well then I guess everyone needs to specify GMT800 or GMT900 in every post, that or dont bitch about repeat threads. :dunno:
NO, THAT WOULD TAKE AWAY TOO MUCH FUN
I pulled the radio to get a little more information.
The part number is 15184933 which is a single CD/tape deck. What I would assume would be the AUX button has the "Band" on one side and the "Tape/Disc" on the other side. The electrical connector is a 24pin piece if that's any help. I called up PIE tech support and they told me I need to call up GM to see if the unit is programmed to allow an external disc changer. If it is, then the aux function will operate.
I'm using the GM12-AUXv2
Got it from Crutchfield (http://www.crutchfield.com/p_469GM12AX2/Pr...v2.html?tp=1672)
All it says you need to be aware of: Factory radio must have "BAND" button in lower left corner of radio.
If you have any questions, I'd say contact Crutchfield support instead, they seem to be the best place that answers any of my questions.
Thanks for the link, I've got one on order. I'll let ya'll know how it turns out.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
