Electronics / 4wd / Atc
rickeyddman
I have a 2001 Z71 bought it about 2 years ago. Noticed shortly after a low but constant drain on the battery, about .5-.75 amperes. which equals dead battery in few days of inactivity. After 2 years of trying to track it down and baffling local mechanics I pulled every fuse one by one to find where the source was.
I can have every other fuse pulled but the ATC and still have the drain. When i pull the ATC fuse the amp drain increases to 1.0A for a few seconds then down to .1A which I assume is as close to zero as its going to get. When I replace the fuse I hear a click from under the truck (transfer case I assume) and get a jump to 1.25A then falls off to .75A after a few seconds and remains there.
Question: Is this a typical characteristic of a bad dash switch or do I have sensor issues or the encoder problems I keep reading about? How do I determine the source without just dropping a wad of cash on all the above?
If no one else knows a specific solution for this....
My way would cost quite a bit. That is to first get the factory wiring diagrams with the service manual set, then see what all is on this circuit. But the factory service manual set is not cheap!
Then you kind of need to be an electronic type to understand the wiring diagrams, so if you're not an electronic type, this might look like Greek to you...
Anyway I would get the factory service manual set and look at the wiring diagrams to see what all is on that particular circuit. And WHERE each device/switch/whatever is located on the truck.
Then learn how each component is supposed to operate, try removing different components and see if this reduces the amperage draw. BUT this can be tricky! There might be a faulty switch powering something and you remove that "something" and the amperage draw decreases!
So you conclude that "something" is the problem, spend $200 to get a new something, install it and same problem. Then learn all along it was the switch controlling that something which was the problem - then get the new switch.
So it is important when troubleshooting this stuff to also understand how everything should operate, then try different things to find the EXACT problem. And be able to test each device to see if it is working ok or not.
I can read schematics so that wouldnt scare me. Before I do all that I'll try a switch from a salvage truck before I purchase all those new parts and maybe that will fix it for the short term. If that doesnt I will take it back to the mechanic I trust the most and show him what I have found and let him trace from there. just was hoping someone else might recognize the symptoms from a previous issue of their own.
Anyone?
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
