Ac Outlet Covers
Hi all,
First time poster. Just joined. If I posted incorrectly or in the wrong spot, sorry, I will learn.
Question is on the AC outlet covers. My 2008 Sierra has two outlets on the dash. Last night, unplugging my GPS I broke the cover hinge. Anyone know where I can buy another one? Thought I would check here before I go to the dealer.
Hi all,
I broke one on mine very quickly. Cheap part but the dealer will replace under warranty for free
