2006 Silverado Posi Problems
DJ_Poop
I took my 2006 Silverado 1500 96,000 k on it to the dealership for regular maintenance, they informed me that my rear diff fluid needed to be replaced I approved. I recieved a call 1 hr later saying that my posi governor had some teeth sheered off. I went down to confirm this and it was true, they are telling me the whole posi system needs to be replaced they cant just replace the little gear that has the teeth sheared off. Anyone else have this happen or know if this is true that they cant just replace the gear? Any help with this would be appreciated
Thank you
Richard
This is a frequent problem with my repairs. I need just a little part, but can only get the whole works! If I could get just the little part, then I could replace just that at a much reduced cost.
Other times it is recommended and best to replace a whole unit. This is because if one part has failed, the rest of the parts will begin failing in the near future, so a long lasting repair would be one where the whole unit is replaced. Other times certain parts are "matched" to other parts and one new part along with other old parts will not work as it should, so best to replace the whole works.
But I think the bottom line is THEY can only get the whole works and don't have the part number for just that gear. I'm sure somewhere in this world that gear exists and maybe someone could track it down and find it. But I have spent hours trying to find these parts and not had any luck. They probably know this and are not going to waste their time.
The other option would be to find the part in a wrecking yard. But I don't know if a wrecking yard would sell just that part or would want to sell the whole works? And I don't know if a dealer would install a used part?
I have one other question if I just leave it the way it is, is that bad will it harm the rest of the diff? could I just have the remaining teeth removed?
Thanx
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
